Windshield wipers are not working
178,000 MILES
SMART1156
I checked the fuse; I think it's good and the washer fluid is still working. anyone know what the problem could be?
Feb 13, 2022 at 6:45 AM
SQM
  • 6,383 POSTS
If the fuse is good the next item, you will have to check is to see if there is power to the wiper motor. The issue could be faulty wiring or bad wiper motor or a bad relay for the wiper motor.
The relay is located under the hood (see diagram below). It will be a good idea to inspect the relay. Look for any burnt pins or corrosion.
If there is power to the motor, then the issue is a faulty motor and will need to be replaced.
Feb 13, 2022 at 12:32 PM
