Windshield wipers will not turn off when key is in the on position
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
TIMEOFLEISURE
Wipers will operate in the pulse position and will not turn off (wipers will turn off when ignition
is turned off). Thanks
Apr 8, 2020 at 6:14 PM
Good morning,
The park control is handled by both the motor itself and the control which is in the fuse block under the hood.
Do you have a voltmeter or test light to do some testing? I attached a wiring diagram for you to view.
In most cases it is the wiper motor itself but needs to be confirmed.
https://www.2carpros.com/articles/how-to-replace-a-windshield-washer-pump
Apr 8, 2020 at 9:10 PM
