windshield wipers not turning off
200 MILES • 4WD • AUTOMATIC
NELLY25
My windshield wipers won't shut off only when I turn the car off, but when I turn on its still on the front ones. I tried the regular way but nothing at all. any ideas will help. thank you
May 13, 2021 at 10:35 AM
JIS001
  • 3,412 POSTS
Hello and thank you for using 2CarPros. The first thing I recommend is removing the fuse for the wipers so you can get it to stop. Second, you need to have the whole system scanned for codes. Your concern that you have would indicate a possible Central Electronic Module fault. Maybe corrosion from an undetected windshield glass leak if it has been replaced or maybe leaking sunroof drains at the "A" pillar on the driver side.
If you have had any type of water intrusion I would suspect either one. Unfortunate If it is the CEM, replacing it would require a re-program as well.
May 13, 2021 at 4:22 PM
NELLY25
Thank you. will try that first will follow up with you soon to tell you how it went.
May 14, 2021 at 5:24 PM
  • 110,251 POSTS
I noticed we haven't heard from you for a couple of days. Have you been able to make any progress? We're interested in knowing.
May 17, 2021 at 2:33 PM
