windshield wiper's are not working
178,500 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
CJJENNINGS
i replaced the wiper motor and there is no power to the motor. the fuse is good and the whole blinker arm that works the works everything but the wipers.
Oct 12, 2017 at 3:45 AM
  • 31,937 POSTS
Sounds as if the wiper switch may be a fault. are you able to test the circuit through the switch with a multi meter?
Oct 12, 2017 at 1:03 PM
CJJENNINGS
No and thank you.
Oct 12, 2017 at 1:25 PM
  • 55,710 POSTS
There are two wiper relays that I would check because I think that is your problem.
Here is a guide and some wiring guides to help you do some easy testing/replacing:
and
Cheers, Ken
Oct 13, 2017 at 4:44 AM
