Windshield wipers stopped working?
97,000 MILES • 2.4L • 5 CYL • 2WD • AUTOMATIC
MLAROE
  • 9 POSTS
Replaced the motor, and nothing. Went to a shop and it worked, got home and stopped working.
Nov 18, 2022 at 1:29 AM
  • 110,251 POSTS
When you took it to the shop, did they do anything to make them work, or did they just decide to work on their own? I
If it was on its own, it sounds like a loose connection or faulty ground. Try this. Turn the key to the run position and the wipers on low, not delay. Wiggle the wiring at the motor to see if they start working.
Try this and let me know the results.
Nov 18, 2022 at 2:57 PM
MLAROE
  • 9 POSTS
Hi Joe, no when it was at the shop, they just turned on the window wipers and it worked. The funny thing is they tried it several times but when I got it home it didn't work. I did what you said, and nothing worked. I think you're probably right about the ground the problem is I can't seem to follow the wires from the wiper motor.
Dec 8, 2022 at 10:44 AM
  • 110,251 POSTS
The ground wire will be brown. Its grounding point is the left front strut tower. See pics 1 and 2
Try to splice a new ground wire in place at the wiper connector and as a test, ground it to the negative battery cable to see if things work properly at that point.
Dec 8, 2022 at 11:36 AM
MLAROE
  • 9 POSTS
Hi Joe, I could not find the ground to the strut, but I made sure the ground was tested and is good. I am thinking it's the switch. Any other ideas?
Dec 27, 2022 at 2:17 AM
  • 110,251 POSTS
Before we replace anything, let's try one more thing. Disconnect the wiper motor. At the connector, there will be a blue wire and a yellow wire. With the key and wipers on low or high, check if either of those wires has power.
Dec 27, 2022 at 9:44 AM
MLAROE
  • 9 POSTS
Happy New Year Joe.
The blue and white has power. The yellow and blue nothing. Made sure the 25-amp fuse is good.
Jan 1, 2023 at 5:47 AM
  • 110,251 POSTS
Happy New Year to you as well. I hope you had a good one.
If you are not getting power to the yellow or blue wire, I think the low/high wiper relay is bad or we have a connection issue. At least, that is what we need to check next.
If you look below, I highlighted the power wires for the motor to run. Both of these wires come through the relay.
The relay is under the hood. See pic below. Remove the relay and if there is another one having the same part number, switch them. If there isn't, inspect the connectors on the relay and where it mounts. Make sure they are clean, and tight, and there are no corrosion issues. If you want to physically test it, here is a link that explains how to do it:
Let me know what you find.
See pic below.
Jan 1, 2023 at 1:12 PM
MLAROE
  • 9 POSTS
Hi Joe, I checked the connectors and they look good .I made sure the realy work by doing the light test with it.
Jan 10, 2023 at 1:47 AM
  • 110,251 POSTS
If the relay is getting power to it (pin 86) and then power is sent out via pin 87 or 87A, the motor must be the problem. However, you indicated there was no power to either the blue wire or the yellow wire at the wiper motor. Is that correct?
Just as a check, disconnect the motor and run battery voltage to the blue wire. Does the wiper motor turn run?
Jan 10, 2023 at 9:48 AM
MLAROE
  • 9 POSTS
Hi Joe, I tested the relay with a multi meter it is good. I tried switching the relay from a different connection, it was the same number on the relay which was 434 . I also tested all the wires again and it's the same.
Jan 11, 2023 at 2:38 AM
  • 110,251 POSTS
I have one last fuse to check. Also, please confirm for me that pin 85 of the high/low relay isn't getting power with the key on and the switch on high or low.
Also, check fuse 34 under the dash on the left side as well as fuse 14. I'm looking at the legend for the wiper motor and it is showing two different fuses for the headlamp wiper motor. Ugh!!! One is likely listed wrong.
Jan 11, 2023 at 6:38 AM
MLAROE
  • 9 POSTS
Hi Joe, I checked the fuse with the multimeter and it is good.
Jan 19, 2023 at 12:54 AM
  • 110,251 POSTS
Okay. Based on all the tests, it sounds like the motor itself is bad. If you look below, I attached the directions for the removal and replacement of the motor.
Take a look through them and let me know if you have questions.
Let me know how things turn out for you.
joe
Jan 19, 2023 at 8:39 AM
MLAROE
  • 9 POSTS
Hi Joe, the mechanic said the problem is the fuse box under the dashboard went bad. Thanks for your help. Take care too.
Jan 30, 2023 at 11:00 PM
  • 110,251 POSTS
Thank you for the update. If I understand, the fuse box failure prevented power from reaching the wiper motor, correct? You checked the fuses I suggested, and they had power and were good, so it must have been right after the fuse. Ugh!!! Anything to make it a bit more difficult to find. LOL
Regardless, I'm glad it was taken care of, and the wipers are working. That is one thing that is needed.
Take care and please feel free to come back anytime in the future.
Jan 31, 2023 at 9:59 AM
MLAROE
  • 9 POSTS
Hi Joe, I have been very busy. Just wanted to say thanks for your help.
Mike
Feb 21, 2023 at 9:59 AM
  • 110,251 POSTS
Mike,
You are very welcome. I'm just glad to know I helped. LOL
You take good care of yourself and please feel free to come back any time in the future. You are always welcome here.
Feb 21, 2023 at 12:47 PM
