are special tools needed to clean or unclog the spray nozzles and then align them?
Apr 21, 2013 at 12:08 AM
✓Experienced Mechanic
you need compressed air to clean them out. they just snap in and no adjustment.
use a good quality washer fluid and they wont clog
Apr 21, 2013 at 12:48 AM
PATRICA123
MEMBER
Fill the syringe with windshield washer fluid and then attach the needle. Insert the needle into the tiny hole of the nozzle and spray the liquid with as much pressure as you can. Repeat the process and then hold down the wiper lever for a few seconds
Sep 13, 2013 at 6:42 PM
TOROVIEJO1979
MEMBER
Thanks for the reply. I will try that if they ever foul up again.
