Windshield washer pump replacement
133,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MDENNER
What to disassemble to access the pump motor for replacement ?
Nov 17, 2019 at 7:07 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny/
The actual pump is mounted in the washer fluid reservoir. If you remove the reservoir from the vehicle there will be an electrical wiring harness connector a a rubber washer line to disconnect.The pump is just a pull out/push in connection in a rubber grommet to seal the pump to reservoir. I've attached pictures below and circled in red.Hope this helps and thanks for using 2CarPros.
Nov 17, 2019 at 8:07 AM
