Can I get a diagram of windshield washer circuit?
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
SENGA
  • 33 POSTS
I have a problem with my windshield washer. I have tested my pump directly to the battery and found that its works normally but when i connect it to the car the wiring can't work. I would like to know is a problem of short-circuit and i would like to ask for a Diagram of windshield washer circuit.
Aug 15, 2022 at 7:04 PM
BORIS K
  • 836 POSTS
See diagram below for WWS system layout.
Please first check that the washer fuse 9, 10A, on the dash fuse board is still intact.
https://fuse-box.info/toyota/toyota-mr2-spyder-w30-1999-2007-fuses
How to check a fuse:
If the fuse is good next check that you have 12V, with ignition on, at pin 2 at the washer pump. This is the blue wire.
How to check for 12V using a test light or voltmeter:
and
If no 12V is present, then next check that the blue wire between fuse 9 and the washer pump is intact.
How to test a wire:
If 12V is present at pin 2 at the washer pump, next check that a ground is applied to pin 1 when the washer switch is activated. If no ground is activated when pulling the washer switch then next check the wire, blue/yellow, between the pump and washer switch.
Hope this helps.
Cheers, Boris
Aug 15, 2022 at 7:58 PM
SENGA
  • 33 POSTS
Hello.
I would like to thank you for the help you have given me with my windshield washer pump. I followed step by step all the steps you gave me to follow the found that it was the pump which was not working. I replaced it, now everything is okay.
Aug 22, 2022 at 3:48 AM
  • 55,732 POSTS
BORIS K is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend. Can you please leave us a rating? (Copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Aug 22, 2022 at 3:49 AM
