my washer worked then stopped
170,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DANBUB55
When it got very cold for days my washer worked then stopped. i have plenty of fluid.
Jan 2, 2018 at 9:01 PM
  • 55,721 POSTS
It could have frozen the washer fluid which is common. They make washer fluid that resists freezing which will help. Can you hear the motor running when you use thee switch?
Here is a guide to help you see what you are in for when doing the job:
https://www.2carpros.com/articles/how-to-replace-a-windshield-washer-pump
Cheers, Ken
May 10, 2021 at 4:54 AM
DANBUB55
Yes, it was frozen. Thanks for your time. I took hot water and poured it on the lines.
  • 55,721 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
