windscreen wiper
275 MILES • 1.3L • 2WD • MANUAL
KEVASHRSA
Toyota tazz windscreen wipers not coming on. It does give a small kick, but then it burns the fuse repeatedly. I don't want to buy a new mechanism motor yet. Just need professioanl advice first Cheers all the way from South Africa
Mar 7, 2016 at 1:39 AM
HMAC300
  • 48,601 POSTS
you really need to have this scanned for codes to verify that the motor is bad as that is what it sounds like. disconnect the switch first and see if it still blows the fuse, if it does then it's a problem between fuse and switch or the switch.
Mar 7, 2016 at 4:23 AM
