Windscreen washer's pump fuse location
2005 HOLDEN RODEO
184,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BARRIE FLANNERY
Where is the washer pump fuse located?
Nov 20, 2019 at 11:03 AM
  • 110,241 POSTS
This vehicle isn't offered in the US so I have no specifics on the fuse location. However, most fuses of this type are located under the hood in the fuse / relay box. Often times, the cover on the box should identify each fuse.
Let me know if you find it.
Nov 21, 2019 at 10:58 AM
BARRIE FLANNERY
Thank you for your response. the fuse for the washer pump is not marked, so i think it may be on the same fuse as the wiper motor. I disconnected the terminal to the washer pump and connected a test light and the circuit tested okay. so now I am looking at the pump!
Regards,
Barrie
Nov 21, 2019 at 4:32 PM
  • 110,241 POSTS
Hi Barrie:
If you have power to it, then I agree. It's the pump. That really isn't an uncommon problem. They just go bad.
If I can help, let me know.
Nov 22, 2019 at 12:40 PM
