Windscreen Washer Pump
93,000 MILES • 1.6L • 4 CYL • 4WD
VIJAI
Sir
i am using my car since long time ,suddenly when i press butten to wipe my Windscreen only wiper works. cant find the water i ckecked all i can do
one of the mech told the problem with motor
can u be able to show the photo of a new motor or old one as a sample
if i buy is it possible to fix my self is it a tough job
pls help me in this
Jan 31, 2016 at 12:45 AM
  • 31,937 POSTS
Remove the washer container and the pump is fitted at the bottom of the plastic container, it just sits in a rubber grommet, you can check the power at the terminal as well, if you have power at the plug replace the pump, very easy job.
Jan 31, 2016 at 4:23 PM
