windows wont go up
JYUSKO1228
My driver side passenger and both passenger side windows will not go up or down when I push on the win down button. Is there a way for me to open up a door panel and force the windows up. I checked all the fuses and no fuses are burnt out.
May 21, 2013 at 9:51 AM
WRENCHTOSS
  • 16 POSTS
Most likely you have bad window motors if you take the door panel off you can connect a fused Jumper to the window motor connector and ground the other side if the window works you have a switch problem..
May 21, 2013 at 10:35 AM
HMAC300
  • 48,601 POSTS
check circuit breaker in fuse box first not fuses. then slam the door and see if the window moves if it does it's a bad motor or the wire going to the motor has broken between door and post. check to make sure power is goin in an dout of master switch and also check that window lock button isn't engaged.
May 22, 2013 at 12:28 AM
