none of the windows work, I have checked fuses. Changed master switch on drivers door. Also there are no interior lights when door is opened.
Jan 8, 2016 at 9:37 PM
HMAC300
✓Experienced Mechanic
have it scanned for codes it may be a driver door module for lights or a class 2 serial data problem. might also be the door latch. for winds check fuses under rear seat and circuit breakers
