The windows will not roll up or down?
200,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
SALLY1001
The windows won't roll up or down it's a new Switch and a new window roller in the driver door.
Sep 25, 2024 at 4:42 AM
  • 55,859 POSTS
When you say roller do you mean motor? If so let's see if the switch is getting power, here is a guide to help and the window wiring diagrams so you can see how the system works and a guide to help check it.
With the key on test the yellow wire at the switch for power. Check out the images (below). Please let us know what happens.
Sep 26, 2024 at 6:01 AM
