Windows
209,702 MILES • 4.6L • V8 • 4WD • AUTOMATIC
ANDREW ZWOLINSKI
Just five minutes ago my driver side window would not go up. I only hear the relay under the dash click when I push the switch down. I hear nothing when I press it up or even when I push the passenger side switch from both drivers door and passenger door. Passenger side window does not go up or down either. It is the relay that's gone bad or something else?
Jun 7, 2016 at 6:49 AM
  • 31,937 POSTS
Master switch may have failed, you will have to remove the door trim and test the circuit at the motor for power and earth when operating the switch,
Jun 7, 2016 at 7:34 AM
