Rear driver side window will not roll up or down
135,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ALEXTTT
  • 59 POSTS
I tried using both switches and nothing. Doesn't make any noises.
Dec 9, 2019 at 5:39 AM
AL514
  • 5,702 POSTS
There may be a break in the wire or wires that run through the rubber tube where all the wires for the door are. You can see it when you open the door. Plus the door covers come off pretty easy, you can pop that cover off and check the wiring directly at the window motor. It's also possible the motor stop working all together. There are usually 2 wires going to the window motor, they are 12 volts each depending on if the window is being commanded up or down.
Mar 21, 2021 at 4:12 AM
ALEXTTT
  • 59 POSTS
I replace the window regulator and it's working! But only at the master switch and if I try to move the window from the rear passenger it wont work on either sides.
AL514
  • 5,702 POSTS
It sounds like the master switch is bad, I know there's alot of wires coming out the switch, but there should be one wire with power going to one of the rear windows when the switch is pushed. Same with the other rear window, it's not too hard if a switch to diagnose.
ALEXTTT
  • 59 POSTS
So if the master switch is bad it wont send power to rear switches?
AL514
  • 5,702 POSTS
Yes, it sends power to the rear switch then to the window motor, that's how you can control the rear windows from the drivers seat.
https://www.2carpros.com/articles/electric-window-repair
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
https://www.2carpros.com/articles/door-panel-removal
