The window washer is not working and fuse is okay. I do not know how to get to it. Mick
Sep 2, 2018 at 9:27 AM
AL514
✓Experienced Mechanic
Hello thanks for using 2CarPros.com. The window washer motor is going to be located in the in the tank for the washer fluid. There is usually a two wire connector going to the motor. Is the window washer not working anymore? We can give you directions to test it make sure it has power if that is the issue.
Sep 2, 2018 at 10:40 AM
MICHAEL PARLE
MEMBER
Hi, no the washer motor is not working and I have checked the fuse. Also, the are two blue rubber pipes coming out from inside drivers side wing and along back of engine bay and then one of the blue pipes goes in under back of air filter compartment. Can you tell me what they are? Thanks in advance! Mick
Sep 2, 2018 at 11:34 AM
Yes, can you shoot a video from your phone or pictures and upload them in your response of what you are talking about? Also, use a test light at the washer motor to see if it is getting power and ground it sounds like the motor is out. Here is a guide to help you:
