Window stuck in the up position... will not roll down...
100,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
SHOEMAN1957
My drivers side window will not roll down so I can access the plastic window guide holders in order to compress them so I can get the glass off of the regulator so I can fix the problem ... question: With the window stuck in the up-position, how do I get the window glass off the regulator in order to fix the problem ?
Dec 8, 2015 at 10:56 PM
MIKE H R
  • 3,094 POSTS
With the window up you will have to take the inside door panel off. most fasteners around the panel are push in so be careful getting them loose. you might have to look around the inside door handle to see if there are screws holding the handle tight. Sometime it takes some moving it around once you have it loose to get it off. there will be wires that will have to be disconnected. Once off you might find a thin piece of insulation to take off. After that you can get to the window trac.
Dec 9, 2015 at 1:45 AM
