Window regulator replacement
105,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
SIERRA GUY TOM
Should the window be up or down before I attempt to remove door panels to remove and replace regulator?
May 10, 2018 at 11:42 AM
  • 110,248 POSTS
Hi and thanks for using 2CarPros.com. There are two different sets of directions. One is for power windows and the other for manual. I am not sure which you have but the directions are primarily the same. As far as your question, I have always found it easiest to have the window in the up position when I start this type of job. When it is down, it is nearly impossible to access anything in the door because the window blocks everything.
Here are general directions for removal of the door panel:
https://www.2carpros.com/articles/door-panel-removal
General directions for window motor and regulator removal and replacement.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Here is a video for replacement. It is a different type of car, but the process is very similar.
https://youtu.be/Wp7Ak9IGs4o
If you look at the first picture, it is how to remove the door panel. I always find it helpful to know where all the clips, screws are located. If you have power windows, here are the directions for removing the panel, switches.
Remove or Disconnect
Negative battery cable.
Accessory Switch Plate Mounting
Switch mounting panel.
Use a flat blade tool to carefully pry door accessory mounting panel from door trim panel.
Power accessory electrical connectors from switches and speaker (if applicable).
Switches from switch mounting panel (if applicable).
Use a flat blade tool to carefully pry switches from accessory mounting panel.
Speaker grill front switch mounting panel (if applicable).
Carefully spread speaker grill retainers.
Speaker from switch mounting panel (if applicable).
Rotate speaker counterclock-wise.
Install or Connect
Speaker to switch mounting panel (if applicable).
Rotate speaker clockwise.
Speaker grill from switch mounting panel (if applicable).
Snap in place.
Switches to switch mounting panel.
Snap in place.
Power accessory electrical connectors to switches and speaker (if applicable).
Snap in place.
To remove the handle bezel:
Handle bezel from door trim panel.
Insert a flat blade tool between the door inside bezel and the handle assembly.
Carefully bend retaining clips outward while pulling out the bezel.
Disconnect the wiring connector (if equipped with power locks).
Install or Connect
Handle bezel to door trim panel.
Connect the wiring connector (if equipped with power locks).
Snap bezel into place.
Here are the directions for windows regulator replacement specific to your vehicle. I've also attached pictures to help.
The power window motor can not be serviced. It is replaced as a unit with the regulator.
Tool Required:
J 34940 Rivet Gun
Trim panel.
Water deflector. Refer to Inner Panel Water.
Inner mounting panel assembly. Refer to Inner Mounting Panel.
Rivets securing the regulator to the door inner panel. Drill out (2) front and (2) rear rivets.
Regulator from inner panel.
Install or Connect
Regulator to inner panel.
Rivets securing the regulator to the door inner panel using J34940.
Water deflector.
Trim panel
There is a lot of information here. I realize you started with a simple question, but the additional information may be helpful if you have never done it. I hope it helps.
Cheers,
May 10, 2018 at 12:56 PM
SIERRA GUY TOM
Should have told you it is driver side and it is electric. Window goes down okay, but sticks going up. Have to pull up, hit switch and repeat until window is all the way up. Last time it had these symptoms I sprayed silicone in window tracks and window worked great, not so much this time. The truck is almost twenty two years old after all.
Thanks, Tom
May 10, 2018 at 1:56 PM
  • 110,248 POSTS
No problem, Tom. I just hope it helps. And as far as the truck's age, I still say they built them better back then. Too much to go wrong with the new ones. lol
May 11, 2018 at 11:33 AM
SIERRA GUY TOM
New window regulator with motor solved my problem.
Thanks for your help.
Tom
May 21, 2018 at 8:15 AM
