driver's side door window controls are not working properly
83,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CHARLIE1229
  • 46 POSTS
I am having a problem with my front passenger window were I cannot put it down from the controls on the driver side door, but it still works fine with the controls on the passenger door.
Mar 6, 2017 at 7:45 PM
HMAC300
  • 48,601 POSTS
It may be the switch is bad on drivers side as that is master switch. check with a test light or volt meter see if it is sending power. if not that there may be a broken wire either in drivers door to jamb or pass door. it should be scanned for codes though to make sure a module is not bad and a mechanic has to do that.
Mar 6, 2017 at 10:20 PM
