Window motor wiring?
47,000 MILES • 7.5L • V8 • 2WD • AUTOMATIC
LIVINTHELIFE
  • 13 POSTS
Hi, I just purchased this big, beautiful car and the only window that rolls down is the driver's window and they also don't roll down from their own switches. The passenger door panel is off, and I'd like to hotwire the window motor just to make sure it's not the window switch or bad wiring. It has a red and a yellow wire going to it. Thanks.
Jan 1, 2023 at 9:37 PM
LIVINTHELIFE
  • 13 POSTS
Also, the other thing that doesn't work is the heater blower motor, just in case if that might be connected.
Jan 1, 2023 at 9:47 PM
  • 55,688 POSTS
These are separate problems please start a new question for the blower motor. You can connect a power and ground to the motor to hot wire it, please reverse the polarity if it does work in case the window is all the way down in which case more down will not make the motor work. Let me know what happens, we don't have wiring diagrams for a car this old, sorry.
Jan 2, 2023 at 5:08 AM
LIVINTHELIFE
  • 13 POSTS
Yup I've done all I can, I believe it's dead. I'm going to attempt to pull the motor apart and maybe clean up the windings and brushes, thanks.
Jan 2, 2023 at 10:27 PM
  • 55,688 POSTS
Yep, it happens, use 2CarPros anytime, we are here to help. Please tell a friend.
Jan 3, 2023 at 3:36 AM
