The window on the driver's side goes up but stops when it's about 3/4 of the way closed. After that point, the motor doesn't make any noise and it cannot go up anymore, only down. If you keep pressing the window button after around 30 seconds, nothing happens. However, if you turn the key off and on again, the motor starts working again for some time.
Aug 10, 2023 at 5:32 AM
