window guide clips
240,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
LANCELOT224
The window was going up lopsided and I removed the door panels. When I looked inside the door I found the guide clips and two black square plastic. I want to know how to replace in the proper sequence.
Apr 27, 2018 at 10:45 AM
  • 55,770 POSTS
I am thinking the regulator might be having a problem allowing the window to dip on one side. Here is a guide and diagrams (below) to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Check out the diagrams (below).
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Apr 29, 2018 at 3:31 AM
