Good afternoon,
If it was a fuse, it would not work at all.
There is a signal sent from the drivers switch to the body control module. The body control module sends a signal back to the drivers switch for the motor to operate in the commanded position.
You need a advanced scan tool to monitor the window signals from the switch to the body control module and to the window motors.
It could be the switch itself, which is a module, the body control module or wiring.
https://www.2carpros.com/articles/electric-window-repair
Aug 19, 2020 at 6:37 AM
