Front passenger door and window not working properly
225,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
TMICHELL76
I cannot lock or unlock my front passenger door. The passenger and driver side switches will lock and unlock all doors except the the front passenger door. Also front passenger window not working at times. Any advice is much appreciated.
Dec 4, 2019 at 7:21 AM
  • 110,248 POSTS
Is there any noise from that door when you try to lock them? Did the problem all happen at once? Have you removed the door panel to see if there are any disconnected wires or damaged ones?
Dec 6, 2019 at 11:15 AM
