Window motor does not work
156,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
TONY DITULLIO
My window is down motor won't work. how do I test my motor when it has ten wires on it?
Mar 4, 2019 at 11:35 PM
  • 55,711 POSTS
See if you have power at the red and white ring. Here is a guide to help you and the window wiring diagrams so you can see how the system works:
Check out the diagrams (below). Please let us know what you find.
Mar 7, 2019 at 1:53 AM
TONY DITULLIO
No power to the red and white power to the red and yellow at the motor.
Mar 7, 2019 at 2:25 AM
  • 55,711 POSTS
Can you check for power at fuse #38. here is a guide and the fuse location:
Mar 9, 2019 at 4:23 AM
