WINDING NOISE
1996 CHEVROLET TRUCK
235,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
HARDHEADSTRONG
My truck is a 1500 z71.with a 10 bolt rear. I recently replaced the pinon seal. Because of leaking problems. I marked everything the way it came out. And put everything back in exactly by my marks. Tightened the nut up on pinon .exactly like it came off. I did put a new universal joint on. Because it needed one.everything is in tack. Added transmission fluid to full line. Problem is when driving forward and backwards at low speed. There is a winding noise. And yes i did put gear oil back in at proper level. Any help is appreciated. Thanks
Oct 1, 2016 at 3:52 AM
HMAC300
  • 48,601 POSTS
you may have tightened pinion up too tight as there has to be a certain drag on the bearings and probably tightened too much.
Oct 1, 2016 at 6:02 AM
HARDHEADSTRONG
Thanks for your answer. I did loosen it up to 20lbs by Gm specs. Doesn't wind loud. But you can still hear it. Guessing i need to put another crush sleeve.
Oct 3, 2016 at 2:47 AM
HMAC300
  • 48,601 POSTS
yo have to be careful with crush sleeves they don't go by torque. it has to have about 5 inch lbs torque with only pinion on a used sleeve and 10-15 inc lbs of drag with a new bearings so a new crush sleeve won't help that much.with your mileage just put up with it.
Oct 3, 2016 at 5:26 AM
