Will turn over but will not run
118,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
APRIL043
we've replaced the fuel pump, the plugs, the wires, alternator, etc. it will not run why is that?
Nov 25, 2019 at 12:45 PM
JONNYB1963
  • 263 POSTS
Good Morning April,
To Answer that question we need to understand the full picture here.
For an engine to run it needs to have 4 basic things. Air, compression, fuel and spark.
It sounds to me like you have a good battery as you are able to crank so the battery, alternator and charging system are not of concern at this time.
What we need to find out what you are not getting in order to make the engine run.
Please see this guide to help you get started (no pun intended):
Also can you answer me this question. Remembering how the engine used to sound when you would normally start it.. does the cranking sound funny as if the engine is spinning faster than normal?
Jon
Nov 25, 2019 at 10:33 PM
