will turn over but will not fire
142,000 MILES • 3.0L • 4 CYL • TURBO • 4WD • MANUAL
THEDIGGS000
comes up with check engine light. Have checked all fuses bar two diodes and checked to see if pump is getting diesel to injectors. Any way of checking for fault codes looked for test wires can only find a cart plug under interior fuse box?
Jan 29, 2017 at 11:59 AM
  • 55,770 POSTS
Hey THEDIGGS000,
These engine had a big problem with the fuel shut off valve hear the engine. Try to out an scanner on it though to make sure this is the issue.
Run some tests and get back to us so we can continue helping you.
Best, Ken
Feb 1, 2017 at 9:30 PM
