Will turn over but no spark?
230,000 MILES • 2.3L • V6 • 2WD • MANUAL
ASHEA7647
It was spitting and sputtering pretty badly and then I went to leave one day and it crank up, but I got to top of my driveway, and it cut off randomly and it will not fire anymore. One coil pack has a crack in it, but I didn’t think that would cause it to not spark at all.
Apr 28, 2025 at 9:48 PM
  • 55,583 POSTS
Oh ya, if the ignition coil has a crack, it is not good, I would get a new one and install it.
Here is a guide to see other causes of a "no spark" condition:
https://www.2carpros.com/articles/no-ignition-spark
Please go over this guide and get back to us.
Apr 30, 2025 at 4:05 AM
ASHEA7647
I got a new well, it’s a used one, I’m about to change it out and see if that’s the problem.
Apr 30, 2025 at 10:24 AM
ASHEA7647
What is the order? I need to put the spark plugs back on in the correct spot.
Apr 30, 2025 at 10:58 AM
ASHEA7647
Does anyone have a diagram of the spark plug wiring? I changed the coil pack and it’s still not firing.
Apr 30, 2025 at 12:23 PM
  • 55,583 POSTS
Here is the firing order, you may have a bad ignition module or crankshaft angle sensor. Also, check the fuses with the key on. Please go over the guide above as well. Check out the images (below).
May 1, 2025 at 2:52 AM
