will start with difficulty but dies as soon as you try to idle the engine
231,000 MILES • 1.5L • 4 CYL • FWD • MANUAL
JBD43
1993 Civic, 1.5 engine. Battery is fully charged and engine will turn over very well. The engine tries to catch but most of the time it wont start or immediately dies. If it does catch and start it will not idle. As soon as you take your foot off the gas pedal it will die. It has new plugs, new ignition coil. Before changing the coil it would not start at all. The plugs looked like the mixture was rich but they were not fouled. The fuel pressure is fine. I checked the TPS and it does have a dead spot on it right about idle speed and I have a new one on order. But the problem does not seem to me to be directly related to the TPS unit because as you decelerate you can tell it is going to die even before the TPS is all the way down to idle.
Sep 11, 2014 at 2:25 AM
SINBAD271
  • 169 POSTS
Make sure you have the firing order right and also make sure you don't have a vacuum hose disconnected
Sep 11, 2014 at 3:46 AM
