SHOWING YOU AN INEXPENSIVE FUEL PRESSURE TEST GAUGE (SOME STORES RENT THEM/ LOAN THEM OUT WITH A DEPOSIT
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_fuel-pressure-test-kit-otc_28031640-p?searchTerm=fuel+pressure+test+gauge
THIS IS HOW I BUY STUFF---ADVANCE AUTO PARTS IS IN YOUR AREA! (I'M DOWN HERE IN S.C.) "A124" WAS WORKING YESTERDAY (HAS BEEN FOR A LONG TIME)---IT WILL SAVE YOU $10 ON THIS PURCHASE ALONE...OTHER STUFF LATER!....SEE HOW THIS WORKS IN THE LINK BELOW
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
REGARDLESS---THIS IS WHAT I WANT YOU TO DO
1ST......GET IN THE CAR AND TURN ALL RACKET MAKERS OFF, WAIT FOR THE TRAIN TO PASS AND THE TRAFFIC NOISE TO STOP, HUSH UP THE YOUNGINS ................THEN TURN THE KEY TO "ON" (NOT START) DO YOU HEAR A 1-2 SECOND "HUM" OF THE FUEL PUMP?
THIS WILL "HUM" EVERY TIME YOU TURN THE KEY TO "ON"...........................................................UNLESS NO POWER IS REACHING THE PUMP....OR THE PUMP IS JUST PLAIN OLE BAD (OR GETTING THERE)
WHEN IT WILL NOT START.......CALM DOWN.....TURN THE KEY TO "ON"..........DO YOU HEAR THE "HUM" OR NOT????........WE WANNA KNOW IF THE PUMP IS OPERATING OR NOT, WHEN IT WILL NOT START
OTHER THINGS COULD BE WRONG----THIS IS A STARTING POINT........RESULTS?
A FUEL PRESSURE TEST WOULD BE A NICE TOUCH TOO!
ALSO GIMME THE EXACT NOMENCLATURE OF YOUR CAR AND THE ENGINE SIZE.....IF NEED-BE, I HAVE ACCESS TO "MITCHELL I", I CAN PULL UP DIAGRAMS OF WHERE FUSES/ RELAYS AND OTHER STUFF IS FOR YOUR CAR, SHOULD WE FIND THAT WE NEED THEM
MY MOM AND DAD HAVE AN '86 T-BIRD, BOUGHT NEW, AND STILL HAVE IT, YEARS AGO I PULLED MY HAIR OUT TRYING TO LOCATE THE RELAY TO THE FUEL PUMP.......IT WAS SORTA WELL HIDDEN IN THE TRUNK.....THE REPAIR MANUAL DID NOT SHOW IT.......I DID NOT HAVE A COMPUTER, MUCH LESS MITCHELL I !
YOUR TURN
THE MEDIC
Jun 25, 2013 at 12:41 PM
