The transmission will shift into gear but the truck will not move?
2000 FORD F-150
170,000 MILES • 4WD • AUTOMATIC
ANGELA NICOLE KOPP
Good morning, my truck is starting right up and will shift into gear but all it does is rev up it won’t engage to move. Is there any possible way it could be something more simple than needing a new transmission?
Jun 4, 2024 at 7:58 PM
  • 55,433 POSTS
Yep, there are some things we can check starting with the fluid level, this guide can help you:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
If the fluid level is okay, when you put the truck into gear, have a helper look under the truck from the side, near the rear of the truck to see if the driveshaft is turning without the truck moving. This will be a sign the differential is having an issue not the transmission. Also, put the truck in reverse and have the helper see if the reverse lights are on, this will help us see if the gear range sensor is working. Please upload pictures or videos in your response to any problems so we can see what to help you with.
Jun 5, 2024 at 10:27 AM
ANGELA NICOLE KOPP
The drive shaft is not turning, you can hear it catching almost but won’t move, the reverse lights are working. What next?
Jun 7, 2024 at 6:16 AM
  • 55,433 POSTS
Did you check the transmission fluid? And if so, please give it a smell to see if it has a burnt smell to it. If it does smell burnt a transmission service may help it, we should run the codes as well. These guides will help, and I have included the instructions for your truck in the images below.
and
Fluid Types
Transmission Fluid Type
4R100 .................... MERCON V
4R70W .................... MERCON V
MERCON ATF is being replaced by MERCON V ATF as a service fluid, per TSB 06-14-4.
Capacities
Transmission Fluid
4R100 .................... 15.5L
4R70W .................... 13.1L
Note: Approximately Dry Fill Capacity
This video shows it as well.
https://youtu.be/HJdcWI6m3J4?si=FTjNhwkDU24UEl5q
Jun 8, 2024 at 4:17 AM
