Will replacing the hybrid battery fix codes P0A7A, P0A94, and P0A80?
2013 TOYOTA PRIUS
155,000 MILES • AUTOMATIC
BULLSHBIL
Hello, I’m looking for some advice about my hybrid system.
I have a Toyota Prius with about 155,000 miles. I scanned the car with an OBD2 scanner and found these permanent codes:
• P0A80
• P0A94
• P0A7A
Recently the dashboard stopped showing the hybrid battery bars and instead displays a message saying “Stop the vehicle in a safe place.” The car also seems to be in limp mode and won’t go much above ~40 mph.
From my research, P0A80 often indicates the hybrid battery pack is failing, and I’m considering replacing the battery myself. However, I’m not sure if the other two codes might indicate a separate issue with the inverter or generator.
My question is:
If I replace the hybrid battery pack, is it likely that these three codes will clear, or should I be diagnosing the inverter or other hybrid components first?
I’m comfortable doing the battery replacement myself, but I’d like to make sure I’m addressing the root cause before buying a replacement battery.
Any advice or diagnostic steps would be greatly appreciated. Thank you.
Mar 8, 2026 at 12:49 PM
  • 55,433 POSTS
Yep, you are correct, the hybrid battery needs to be replaced. The other codes should go away when the battery is replaced, here is the video to show you how.
https://www.youtube.com/watch?v=m51LUp5OZmQ
Clear the codes once the job is completed. Please use 2CarPros anytime we are here to help. Ken
Mar 10, 2026 at 1:11 AM
