Will not turnover?
90,000 MILES • 1.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
DAVID ALBAUGH
Intermittently will not turnover and the will turn and run fine several times. And do it again.
Sep 9, 2024 at 3:18 AM
  • 55,745 POSTS
So, are you saying the engine will not crank over (starter operation) or the engine cranks over but does not run sometimes? If it is the starting operation here is a video that can help:
https://youtu.be/6YRW8fyNudY?si=OAQk3Wgvp6lHZKXT
Chances are the battery cables are loose or corroded, this guide can help:
I need more information to help you. Please go over these guides and get back to us.
Sep 9, 2024 at 5:08 AM
