Will not start
94,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
ROBBBBBBB
My car will crank but will not turn over. I changed the crank shaft sensor and relay number 100. Once I changed the relay it will start right up, but after I wait a while and try to start it will crank but will not start. It has a half a tank of gas, and I also changed the cam sensor. Can some one please help me figure out what is wrong with my car? Thanks.
Jan 10, 2018 at 3:24 AM
  • 55,694 POSTS
It sounds like you have a fuel pump that has gone out, but before we go there lets run the codes to see if anything comes up.
Here is guide to help you get the job done:
Please run this test and get back to us.
Cheers, Ken
Jan 11, 2018 at 5:30 AM
