Will not turn over
96,000 MILES • 3.7L • 5 CYL • 4WD • AUTOMATIC
TIMMMAT000
Would not crank over for me. All my lights work also. Looked at fuses and notice the starter relay fuse was sitting crocked. I push it back into place and tried again and still nothing so I am wondering if it is the fuse is bad or the solenoid?
Oct 31, 2018 at 9:12 PM
  • 110,248 POSTS
I am not sure why the fuse was not straight, but it needs checked first. Here is a quick link showing how to check a fuse. Also, when you remove the fuse, confirm that the pins it plugs into are not pushed in, corroded, or damaged.
_____________________
Here is a link for testing the starter/solenoid. The smaller wire on the starter solenoid should receive 12 volts power when the key is in the start position. Take a look through this link for details.
Nov 1, 2018 at 9:51 AM
