The engine will not stay running?
160,000 MILES • 4.0L • 6 CYL • 4WD • MANUAL
WILLIAM STEPHENS2
The engine will start but when you give it gas it just idles and then quits.
Nov 14, 2022 at 8:28 AM
  • 110,248 POSTS
Either we are not getting the fuel needed or there is a large vacuum leak. When it starts, does it idle normally or does it have a rough idle? Are there any odd odors or smoke from the exhaust?
Do me a favor. We need to see if there are codes stored in the computer that may help. This vehicle has an OBD1 system that doesn't require a scanner.
Follow the directions in this link and let me know what is found:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Let me know what you find.
Nov 15, 2022 at 1:14 PM
