Will not start sometimes, sometimes fired right up
210,000 MILES
SHERRYODOM1
Get in car, turn the switch on, fuel gauge goes straight to fuel, car will not start. Leave the switch on might take one minute, ten minutes, or four hours. Fuel gauge will click off full and car will fire right up. Someone told me it might be the security wire located on the ignition cylinder or the ignition switch. Which one of these two is the security wire attached to. I have been stranded so many time in the last month, I could scream.
Sep 1, 2017 at 3:50 PM
JDL
  • 16,098 POSTS
When the problem is ongoing, does it crank okay? Is there a security/theft lamp on the dash that is on or flashing? If the vehicle cranks okay when problem is ongoing and no security lamp on, the security system wouldn't be my first thought.
If it cranks good but will not start, check the basics. Have a helper crank it while you check for spark at the plugs. If spark everywhere, use a gauge and check proper fuel pressure and fuel injector pulse. Have to test when problem is ongoing. Any applicable trouble codes? To check codes, at the least, you need an obd2 code reader.
Sep 2, 2017 at 3:44 AM
