Timing belt broke, replaced it, now backfires. tries to start but never starts.
Dec 8, 2017 at 1:08 PM
WRENCHTECH
✓Experienced Mechanic
This engine very rarely survives a broken timing belt. It is an interference engine so the second the belt brakes, the pistons hit the valves and bend them. A leak down test with answer that, but you are likely looking at a new engine if that is the case.
Dec 9, 2017 at 8:22 AM
PERFECTION51295
MEMBER
No way to replace valves?
Dec 9, 2017 at 8:45 AM
WRENCHTECH
Not with 194,000 miles on it. The lower end is too far worn out and would not handle the pressure of the top end being rebuilt. A used engine would be your smartest move once you confirm the valve problem.
Dec 9, 2017 at 8:48 AM
PERFECTION51295
MEMBER
What if I just replace the couple that are bent?
Dec 9, 2017 at 9:09 AM
PERFECTION51295
MEMBER
I really cannot afford new engine.
Dec 9, 2017 at 9:11 AM
WRENCHTECH
Unfortunately it does not work that way. First of all there may be piston damage from the impact. The valve seats and valve guides are going to have a lot of wear so a new valve just is not going to mate up to the head without a lot of machine work first. You cannot machine only some cylinders. There just is not any way to do a patch job.
