Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Engine
Symptoms
Not Running
Will not start after engine overhaul
2004 CHEVROLET BLAZER
147,000 MILES • 4.3L
LOWRIDIN1977
MEMBER
I have spark, fuel, no security light. all new components; plugs, wires, cap rotor. it is in time, but it will not start only turns over.
Nov 29, 2017 at 1:59 AM
Experienced Mechanic
Do you have fuel pressure? Can you check this next? Do a scan as well as not all codes will set a check light.
Nov 29, 2017 at 5:06 AM
LOWRIDIN1977
MEMBER
i have fuel pressure even at startup. i have a snap on Solus Edge 2016 model and do not see any codes.
Nov 29, 2017 at 5:37 AM
Compression okay? valve timing checked and correct? injection pulse and a good spark? Check to see if the plugs are wet with fuel and advise please.
Nov 29, 2017 at 1:15 PM
LOWRIDIN1977
MEMBER
Timing is good, has good spark. the plugs are getting wet with fuel i did notice that.
Nov 29, 2017 at 1:28 PM
Are injectors pulsing or stuck open?
Nov 29, 2017 at 3:32 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
