Will not start after engine overhaul
LOWRIDIN1977
  • 2004 CHEVROLET BLAZER
  • 4.3L
  • 147,000 MILES
I have spark, fuel, no security light. All new components; plugs, wires, cap rotor. It is in time, but it will not start only turns over.
Wednesday, November 29th, 2017 AT 9:59 AM
  • 31,937 POSTS
Do you have fuel pressure? Can you check this next? Do a scan as well as not all codes will set a check light.
Wednesday, November 29th, 2017 AT 1:06 PM
LOWRIDIN1977
I have fuel pressure even at startup. I have a snap on Solus Edge 2016 model and do not see any codes.
Wednesday, November 29th, 2017 AT 1:37 PM
  • 31,937 POSTS
Compression okay? Valve timing checked and correct? Injection pulse and a good spark? Check to see if the plugs are wet with fuel and advise please.
Wednesday, November 29th, 2017 AT 9:15 PM
LOWRIDIN1977
Timing is good, has good spark. The plugs are getting wet with fuel I did notice that.
Wednesday, November 29th, 2017 AT 9:28 PM
  • 31,937 POSTS
Are injectors pulsing or stuck open?
Wednesday, November 29th, 2017 AT 11:32 PM
