Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Daewoo
Lanos
Engine
Symptoms
Not Running
will not start
2000 DAEWOO LANOS
200,000 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
BWREDFORD
MEMBER
1 POST
No spark and no fuel pressure, cranks okay.
May 11, 2019 at 8:14 AM
Experienced Mechanic
Welcome to 2CarPros.
First, here is a link that discusses the most common reasons for a crank no start condition. Take a look through it.
The first things I need you to check will be simple. I need the fuel pump fuse and the ignition fuse checked. The fuel pump fuse (Ef16) is under the hood in the power distribution box. See pictures 1 and 2. Confirm it is good.
Next, I need you to check ignition coil fuse f15 in the interior fuse box. See pics 3, 4, and 5.
Here are a few links you may find helpful when testing the fuses and for power:
Let me know the results.
Images (Click to enlarge)
May 11, 2019 at 1:52 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
