Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Engine
Symptoms
Not Running
Will not start
1988 FORD F-250
120,000 MILES • 5.8L • V8 • 4WD • MANUAL
SAM AROLA
MEMBER
1 POST
Fuel pump runs along time before shutting down. replaced fuel pump and fuel regulator.
Jan 13, 2019 at 11:49 AM
Experienced Mechanic
Good morning,
You need three things to run. Spark, fuel pressure and compression.
Check for spark at the plugs while cranking.
Check the fuel pressure at the schraeder valve on the fuel rail.
And lastly, check the compression. One of them will be missing.
Jan 13, 2019 at 7:15 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
