Will not start
120,000 MILES • 5.8L • V8 • 4WD • MANUAL
SAM AROLA
Fuel pump runs along time before shutting down. replaced fuel pump and fuel regulator.
Jan 13, 2019 at 11:49 AM
Good morning,
You need three things to run. Spark, fuel pressure and compression.
Check for spark at the plugs while cranking.
Check the fuel pressure at the schraeder valve on the fuel rail.
And lastly, check the compression. One of them will be missing.
Jan 13, 2019 at 7:15 PM
