car shut off while driving. replaced distributor, fuel pump, crankshaft position sensor. spark to distributor, but will not start.
Feb 28, 2017 at 6:32 AM
HMAC300
✓Experienced Mechanic
scan for codes first may be out of time as distributor was replaced or you have a sensor not allowing it to start like either a map sensor or engine coolant sensor. also, check for a vacuum leak to MAP.
Feb 28, 2017 at 10:57 PM
RTDDAD
MEMBER
Thank you. will check these. We have spark to distributor, just will not fire.
Mar 1, 2017 at 6:11 AM
HMAC300
if it sparks to distributor from coil then check the rotor and or for a cracked dist cap. also was it put in correctly as you changed it check that.
