Will not start
190,000 MILES • 2.0L • 6 CYL • AUTOMATIC
BRIAN
While driving lost all power and coasted to stop. change fuel pump but now computer will not read. what can it be?
May 20, 2020 at 7:46 AM
  • 110,248 POSTS
When you say the computer won't read, do you mean a scanner won't connect? If so, does the scan tool get power from the vehicle?
Also, here is a link that you may find helpful. It discusses the most common causes of a crank no start. Take a look through it and see if anything helps.
Also, let me know if you checked for spark and fuel to the engine. Here are a couple links explaining how it's done:
Also, let me know what size engine is has. Is it a 6 cylinder or a 4 cylinder. You have both listed above.
Feb 8, 2021 at 4:19 AM
