Will not start just clicks
180,000 MILES
MARCUS585894
  • 5 POSTS
Starter just clicks, no radio or some light and not all of the dash lights come on.
Sep 20, 2018 at 10:02 PM
  • 110,248 POSTS
First, when you only get a click from the starter, either the starter is bad, you have a very weak battery, or you have a bad connection to the battery.
Here are a few links to review. They discuss in detail what I mentioned.
The above links show how to check a battery, clean and inspect battery terminals, and how to check a starter. Check those things and let me know what you find or if you have other questions.
Sep 21, 2018 at 11:38 AM
MARCUS585894
  • 5 POSTS
I checked battery it is new and holding a good charge. Cleaned battery cables still nothing. Need to check starter tomorrow. Would and starter not let the radio or some light come on? Headlights work.
Sep 21, 2018 at 12:51 PM
MARCUS585894
  • 5 POSTS
I mean the dome light will not come on.
Sep 21, 2018 at 12:52 PM
  • 110,248 POSTS
The starter and interior lights/radio are on separate circuits, so that should not happen. Have you checked fuses?
Sep 21, 2018 at 2:00 PM
MARCUS585894
  • 5 POSTS
Yes I have checked fuses all good. Whatever it is it all started when the starter would just click.
Sep 21, 2018 at 2:38 PM
  • 110,248 POSTS
That is a tough one. The first thing I think of is a ground issue. Check the main ground from the battery to the engine block. Then, check if there are additional grounds from the battery ground to the body. See if anything is corroded, loose or damaged.
Sep 22, 2018 at 10:40 AM
MARCUS585894
  • 5 POSTS
I took the ground cable off cleaned good put it back on and the car started right up. For some reason the dome light still does not come on bulb may be blown. Thanks for your help.
Sep 23, 2018 at 9:15 AM
  • 110,248 POSTS
Happy to help. Let me know if you have other questions. By the way, there was a technical service bulletin for intermittent dome light issues. It is not a recall, but the TSB indicated there were several concerns. I attached the diagnosis flow chart for you to see in case the bulb itself is not the issue.
I hope this helps you.
Sep 23, 2018 at 12:30 PM
