Engine cranks, will not start?
2,000,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
TIMOTHY CASSO
I try to start my car. It turns over everything works as it should except it won’t start.
Apr 23, 2023 at 5:47 AM
  • 110,244 POSTS
The most common cause of a crank no start condition is either no fuel to the engine or loss of ignition spark.
Here is what I need you to do. First, see if the engine starts if you use starting fluid. If it does or tries to start and then stalls, we know it is a fuel-related issue. If there is no change using starting fluid, then we need to check for spark at the spark plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If you could, record it cranking and upload it for me to hear.
Do this and let me know the results.
joe
Apr 23, 2023 at 2:37 PM
